Samsung UBD-K8500 Power Supply Board Replacement
  1. Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: step 1, image 1 of 2 Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: step 1, image 2 of 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Power Supply Board Replacement: step 2, image 1 of 2 Samsung UBD-K8500 Power Supply Board Replacement: step 2, image 2 of 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: step 3, image 1 of 2 Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: step 3, image 2 of 2
    • Using your fingers, carefully pinch the clipping part of the two connectors and gently pull them out of their sockets.
  4. Samsung UBD-K8500 Power Supply Board Replacement: step 4, image 1 of 2 Samsung UBD-K8500 Power Supply Board Replacement: step 4, image 2 of 2
    • Remove the four 7 mm screws from the power supply board using a Phillips #0 screwdriver.
  5. Samsung UBD-K8500 Power Supply Board Replacement: step 5, image 1 of 1
    • Gently remove the power supply board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 94
