Samsung UBD-M8500 Fan Replacement
  1. Samsung UBD-M8500 Fan Replacement, Outer Shell: step 1, image 1 of 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Fan Replacement: step 2, image 1 of 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Fan Replacement: step 3, image 1 of 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Fan Replacement: step 4, image 1 of 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Fan Replacement, Fan: step 5, image 1 of 2 Samsung UBD-M8500 Fan Replacement, Fan: step 5, image 2 of 2
    • Remove the two screws on the back of the device, using a Phillips #1 screwdriver.
  6. Samsung UBD-M8500 Fan Replacement: step 6, image 1 of 2 Samsung UBD-M8500 Fan Replacement: step 6, image 2 of 2
    • Grip the white fan connector and pull it directly out if its port.
  7. Samsung UBD-M8500 Fan Replacement: step 7, image 1 of 1
    • Lift the fan out of the device.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 294
