Samsung UBD-M8500 Motherboard Replacement
  1. Samsung UBD-M8500 Motherboard Replacement, Outer Shell: step 1, image 1 of 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Motherboard Replacement: step 2, image 1 of 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Motherboard Replacement: step 3, image 1 of 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Motherboard Replacement: step 4, image 1 of 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Samsung UBD-M8500 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Remove the two ribbon cables from the motherboard.
    • Be careful while doing so because they are fragile.
  6. Samsung UBD-M8500 Motherboard Replacement: step 6, image 1 of 3 Samsung UBD-M8500 Motherboard Replacement: step 6, image 2 of 3 Samsung UBD-M8500 Motherboard Replacement: step 6, image 3 of 3
    • Remove the three cables on the left side.
  7. Samsung UBD-M8500 Motherboard Replacement: step 7, image 1 of 2 Samsung UBD-M8500 Motherboard Replacement: step 7, image 2 of 2
    • Remove the four screws from the corners of the motherboard with the Phillips #1 screwdriver.
    • Lift the motherboard up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 73
