Samsung UBD-M8500 Optical Drive Replacement
  1. Samsung UBD-M8500 Optical Drive Replacement, Outer Shell: step 1, image 1 of 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Optical Drive Replacement: step 2, image 1 of 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Optical Drive Replacement: step 3, image 1 of 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Optical Drive Replacement: step 4, image 1 of 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Optical Drive Replacement, Optical Drive: step 5, image 1 of 1
    • The disc drive is located to the right of the unit, it will be a large metallic rectangular box.
  6. Samsung UBD-M8500 Optical Drive Replacement: step 6, image 1 of 2 Samsung UBD-M8500 Optical Drive Replacement: step 6, image 2 of 2
    • There are two blue ribbon cables located just to the right of the optical drive. Remove the cables by unhooking the thin clip on the motherboard and then pulling them gently from their sockets.
  7. Samsung UBD-M8500 Optical Drive Replacement: step 7, image 1 of 3 Samsung UBD-M8500 Optical Drive Replacement: step 7, image 2 of 3 Samsung UBD-M8500 Optical Drive Replacement: step 7, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the four screws securing the optical drive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 83
