Samsung WB350F Menu/Control Buttons Replacement
  1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: step 1, image 1 of 3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: step 1, image 2 of 3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: step 1, image 3 of 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Menu/Control Buttons Replacement: step 2, image 1 of 3 Samsung WB350F Menu/Control Buttons Replacement: step 2, image 2 of 3 Samsung WB350F Menu/Control Buttons Replacement: step 2, image 3 of 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Menu/Control Buttons Replacement: step 3, image 1 of 3 Samsung WB350F Menu/Control Buttons Replacement: step 3, image 2 of 3 Samsung WB350F Menu/Control Buttons Replacement: step 3, image 3 of 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Menu/Control Buttons Replacement: step 4, image 1 of 1
    • Remove the plastic casing, exposing the inner workings of the camera.
  5. Samsung WB350F Menu/Control Buttons Replacement, Screen: step 5, image 1 of 2 Samsung WB350F Menu/Control Buttons Replacement, Screen: step 5, image 2 of 2
    • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
    • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
  6. Samsung WB350F Menu/Control Buttons Replacement: step 6, image 1 of 1
    • Move the menu button panel to the right as well as the screen.
    • Be careful because each are connected to the camera by a ribbon.
  7. Samsung WB350F Menu/Control Buttons Replacement: step 7, image 1 of 1
    • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
  8. Samsung WB350F Menu/Control Buttons Replacement: step 8, image 1 of 2 Samsung WB350F Menu/Control Buttons Replacement: step 8, image 2 of 2
    • Remove the silver panel.
  9. Samsung WB350F Menu/Control Buttons Replacement: step 9, image 1 of 2 Samsung WB350F Menu/Control Buttons Replacement: step 9, image 2 of 2
    • Flip the screen back over.
    • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
  10. Samsung WB350F Menu/Control Buttons Replacement: step 10, image 1 of 2 Samsung WB350F Menu/Control Buttons Replacement: step 10, image 2 of 2
    • Carefully detach both ribbons by gently pulling one at a time.
    • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
    • Be sure to pull gently as you do not want to break either ribbon.
  11. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: step 11, image 1 of 3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: step 11, image 2 of 3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: step 11, image 3 of 3
    • Gently pull the ribbon in order to remove the menu/control button panel.
    • The ribbon isn't secured with a connector and you are able to pull it straight out.
Taylor Joubert
273 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,374
