Samsung WB35F Menu/Control Buttons Replacement
  1. Samsung WB35F Menu/Control Buttons  Replacement, Rear Case: step 1, image 1 of 3 Samsung WB35F Menu/Control Buttons  Replacement, Rear Case: step 1, image 2 of 3 Samsung WB35F Menu/Control Buttons  Replacement, Rear Case: step 1, image 3 of 3
    • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
    • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
  2. Samsung WB35F Menu/Control Buttons  Replacement: step 2, image 1 of 2 Samsung WB35F Menu/Control Buttons  Replacement: step 2, image 2 of 2
    • Using the spudger, and plastic opening tool open the casing of camera.
  3. Samsung WB35F Menu/Control Buttons  Replacement: step 3, image 1 of 3 Samsung WB35F Menu/Control Buttons  Replacement: step 3, image 2 of 3 Samsung WB35F Menu/Control Buttons  Replacement: step 3, image 3 of 3
    • Once you open the camera case, you will be able to work on any part of the camera.
  4. Samsung WB35F Menu/Control Buttons  Replacement, Menu/Control Buttons: step 4, image 1 of 2 Samsung WB35F Menu/Control Buttons  Replacement, Menu/Control Buttons: step 4, image 2 of 2
    • Carefully unplug the ribbon from the Menu/Control board.
  5. Samsung WB35F Menu/Control Buttons  Replacement: step 5, image 1 of 1
    • Once you unplug the ribbon. Take out the old board and replace it with new menu/control board.
Sarmad Khan
525 Reputation
5 Guides authored
USF Tampa, Team 1-6, Tanski Winter 2015 Member of USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 736
