Samsung WB850F Control Panel Replacement
  1. Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 1 of 3 Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 2 of 3 Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: step 2, image 1 of 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: step 3, image 1 of 2 Samsung WB850F Control Panel Replacement: step 3, image 2 of 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
Jousling Vazquez
431 Reputation
4 Guides authored
USF Tampa, Team 12-4, Eyestone Spring 2016 Member of USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Members
8 Guides authored
One Comment
Only problem .. Where can I buy a replacement control panel.
D Traynor - Reply
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 16
All Time: 729
