Samsung Watch Active Battery Replacement
  1. Samsung Watch Active Battery Replacement, Tools: step 1, image 1 of 1
    • Assemble all your tools
  2. Samsung Watch Active Battery Replacement: step 2, image 1 of 1
    • Turn watch faced down to reveal the screws. Remove the straps by pulling on pin switches to release.
  3. Samsung Watch Active Battery Replacement: step 3, image 1 of 2 Samsung Watch Active Battery Replacement: step 3, image 2 of 2
    • remove the 4 screws
  4. Samsung Watch Active Battery Replacement: step 4, image 1 of 1
    • Use the tin metal pry tool to gently penetrate the back.
  5. Samsung Watch Active Battery Replacement: step 5, image 1 of 1
    • Use the metal pry tool as support for the opening blue pick
  6. Samsung Watch Active Battery Replacement: step 6, image 1 of 1
    • Gently Lift the back to reveal a connector, use a tweezer to remove it then you will have access to the back
  7. Samsung Watch Active Battery Replacement: step 7, image 1 of 1
    • Separate back fully from rest of the body
  8. Samsung Watch Active Battery Replacement: step 8, image 1 of 1
    • use tweezer to remove all 3 connectors and remove the screw
  9. Samsung Watch Active Battery Replacement: step 9, image 1 of 1
    • Use Spudger to lift panel housing from body
  10. Samsung Watch Active Battery Replacement: step 10, image 1 of 1
    • Remove housing from watch body
  11. Samsung Watch Active Battery Replacement: step 11, image 1 of 1
    • Lift off motherboard and use tweezer to lift up bettery connector from the plastic housing
  12. Samsung Watch Active Battery Replacement: step 12, image 1 of 1
    • use spudger to lift battey out of plastic housing
  13. Samsung Watch Active Battery Replacement: step 13, image 1 of 1
    • Separate battery from the plastic body, then install replacement battery
4 other people completed this guide.
Jimi Aloba
347 Reputation
1 Guide authored
2 Guide Comments
I have so benefited from this portal , I have now made my own contribution. Hope it helps someone.
Jimi Aloba - Reply
Excellent guide Haven't done it yet. Where can I find the battery for this watch, also what type of screwdriver are you using for the 1st 4 screws? None of mine fit it.
mnmacd - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 41
All Time: 1,717
