Samsung Watch Active Sensor Array Replacement
  1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: step 1, image 2 of 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: step 3, image 3 of 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: step 4, image 2 of 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
  6. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: step 6, image 1 of 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: step 6, image 2 of 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: step 6, image 3 of 3
    • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
    • Carefully twist the opening pick to separate the sensor array from the back cover.
  7. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: step 7, image 1 of 2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: step 7, image 2 of 2
    • Remove the sensor array from the back cover.
Tobias Isakeit
119,221 Reputation
189 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 49
All Time: 3,944
