Samsung YP-P3 Case Backplate Replacement
  1. Samsung YP-P3 Case Backplate Replacement, Case Backplate: step 1, image 1 of 1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Case Backplate Replacement: step 2, image 1 of 1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Case Backplate Replacement: step 3, image 1 of 2 Samsung YP-P3 Case Backplate Replacement: step 3, image 2 of 2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
Andrew Groeneveld
567 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 934
