Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement
  1. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Sandisk Sansa m230 Series mp3 player Teardown: step 1, image 1 of 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 2, image 1 of 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 3, image 1 of 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 4, image 1 of 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 5, image 1 of 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 6, image 1 of 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Headphone Jack: step 7, image 1 of 1
    • Locate the headphone jack on the motherboard.
  8. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 8, image 1 of 1
    • Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
    • The solder and soldering iron are very hot! Do not touch unless you are wearing appropriate protective gloves.
  9. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 9, image 1 of 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 9, image 2 of 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 9, image 3 of 3
    • Use soldering iron to melt the existing solder at the three headphone jack connections.
  10. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 10, image 1 of 1
    • Remove the faulty headphone jack from the motherboard.
  11. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 11, image 1 of 1
    • Align the new headphone jack appropriately on the motherboard for soldering.
  12. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 12, image 1 of 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 12, image 2 of 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: step 12, image 3 of 3
    • Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
    • Allow the new solder to cool and harden before reassembling the MP3 player.
James Thorne
638 Reputation
6 Guides authored
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,174
