Sansa e260R Battery Replacement
  1. Sansa e260R Battery Replacement, Rear Case: step 1, image 1 of 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Battery Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Battery Replacement: step 3, image 1 of 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Battery Replacement, Battery: step 4, image 1 of 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Casey Smith
111 Reputation
3 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 2,715
