Sansa e260R Rear Case Replacement
  1. Sansa e260R Rear Case Replacement, Rear Case: step 1, image 1 of 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Rear Case Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Rear Case Replacement: step 3, image 1 of 1
    • Pull the rear panel off of the Sansa e260R.
Casey Smith
111 Reputation
3 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,706
