Sanyo VPC S1275 LCD Screen Replacement
  1. Sanyo VPC S1275 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 LCD Screen Replacement: step 2, image 1 of 1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 LCD Screen Replacement, Case: step 3, image 1 of 3 Sanyo VPC S1275 LCD Screen Replacement, Case: step 3, image 2 of 3 Sanyo VPC S1275 LCD Screen Replacement, Case: step 3, image 3 of 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 LCD Screen Replacement: step 4, image 1 of 2 Sanyo VPC S1275 LCD Screen Replacement: step 4, image 2 of 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 LCD Screen Replacement: step 5, image 1 of 3 Sanyo VPC S1275 LCD Screen Replacement: step 5, image 2 of 3 Sanyo VPC S1275 LCD Screen Replacement: step 5, image 3 of 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 LCD Screen Replacement: step 6, image 1 of 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 LCD Screen Replacement: step 7, image 1 of 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: step 8, image 1 of 2 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: step 8, image 2 of 2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  9. Sanyo VPC S1275 LCD Screen Replacement: step 9, image 1 of 1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
Evan Perez
19 Reputation
2 Guides authored
Cal Poly, Team 24-24, Regan Spring 2010 Member of Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 3,118
