Sanyo VPC-T850 LCD Display Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sanyo VPC-T850 LCD Display Replacement, Disconnect the Ribbon: step 1, image 1 of 2 Sanyo VPC-T850 LCD Display Replacement, Disconnect the Ribbon: step 1, image 2 of 2
    • Use caution not to damage ribbon when disconnecting.
    • The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
    • Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
    • Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
  2. Sanyo VPC-T850 LCD Display Replacement, Remove LCD Screen: step 2, image 1 of 1
    • The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Jonathan Yau
26 Reputation
4 Guides authored
Cal Poly, Team 27-95, Amido Spring 2010 Member of Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,525
