Sanyo VPC-T850 Outer Casing Replacement
  1. Sanyo VPC-T850 Outer Casing Replacement, Battery: step 1, image 1 of 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Outer Casing Replacement: step 2, image 1 of 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Outer Casing Replacement: step 3, image 1 of 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Outer Casing Replacement: step 4, image 1 of 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: step 5, image 1 of 3 Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: step 5, image 2 of 3 Sanyo VPC-T850 Outer Casing Replacement, Outer Casing: step 5, image 3 of 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Outer Casing Replacement: step 6, image 1 of 2 Sanyo VPC-T850 Outer Casing Replacement: step 6, image 2 of 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Outer Casing Replacement: step 7, image 1 of 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Outer Casing Replacement: step 8, image 1 of 2 Sanyo VPC-T850 Outer Casing Replacement: step 8, image 2 of 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Outer Casing Replacement: step 9, image 1 of 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
James Robinson
459 Reputation
4 Guides authored
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 169
