Scentsy Warmer Light Bulb Replacement
  1. Scentsy Warmer Light Bulb Replacement, Light Bulb Replacement: step 1, image 1 of 1
    • Unplug the device's power cord from the electrical outlet.
    • If the warmer was running before you turn it off and unplug the device from its outlet, wait for the warmer to cool down (approximately 15 minutes) before you continue to the next step.
  2. Scentsy Warmer Light Bulb Replacement: step 2, image 1 of 1
    • Remove the wax warmer dish from the device.
  3. Scentsy Warmer Light Bulb Replacement: step 3, image 1 of 2 Scentsy Warmer Light Bulb Replacement: step 3, image 2 of 2
    • Carefully unscrew the light bulb from its socket in a counterclockwise direction.
    • Remove the light bulb from the device.
  4. Scentsy Warmer Light Bulb Replacement: step 4, image 1 of 2 Scentsy Warmer Light Bulb Replacement: step 4, image 2 of 2
    • Check the wattage of the light bulb at the bottom of the device.
    • Make sure you have the correct wattage for the new light bulb in hand to replace the old one with.
  5. Scentsy Warmer Light Bulb Replacement: step 5, image 1 of 1
    • Screw in the new light bulb in a clockwise direction.
  6. Scentsy Warmer Light Bulb Replacement: step 6, image 1 of 1
    • Place the wax warmer dish back on top of the device.
  7. Scentsy Warmer Light Bulb Replacement: step 7, image 1 of 1
    • Plug the power cord back in to the electrical outlet.
  8. Scentsy Warmer Light Bulb Replacement: step 8, image 1 of 1
    • Add in a few cubes of wax.
    • For a mid size or larger warmer such as this one, use two cubes at a time, at the most. For a smaller size warmer, you only need one cube at a time. Adding more than the suggested cubes of wax to a warmer could lead to the wax not being melted all the way.
    • Turn the device on.
    • Make sure the device is powering on by observing the light indication.
Once complete, the warmer should turn on and melt the wax completely, creating a good fragrance in your household.
2 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 92
All Time: 5,987
