Sceptre X9 Komodo VII Board Cover Replacement
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: step 1, image 1 of 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: step 2, image 1 of 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: step 3, image 1 of 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: step 4, image 1 of 3 Sceptre X9 Komodo VII Board Cover Replacement: step 4, image 2 of 3 Sceptre X9 Komodo VII Board Cover Replacement: step 4, image 3 of 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: step 5, image 1 of 2 Sceptre X9 Komodo VII Board Cover Replacement: step 5, image 2 of 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Ted Hsueh
170 Reputation
3 Guides authored
Cal Poly, Team 16-56, Forte Fall 2012 Member of Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 488
