Sceptre X9 Komodo VII Power Supply Unit Replacement
  1. Sceptre X9 Komodo VII Power Supply Unit Replacement, Stand: step 1, image 1 of 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 2, image 1 of 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Power Supply Unit Replacement, Board Cover: step 3, image 1 of 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 4, image 1 of 3 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 4, image 2 of 3 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 4, image 3 of 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 5, image 1 of 2 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 5, image 2 of 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Power Supply Unit Replacement, Power Supply Unit: step 6, image 1 of 1
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  7. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 7, image 1 of 3 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 7, image 2 of 3 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 7, image 3 of 3
    • Unplug the seven connections from the power supply unit by gently pulling on them.
  8. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 8, image 1 of 1
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
  9. Sceptre X9 Komodo VII Power Supply Unit Replacement: step 9, image 1 of 2 Sceptre X9 Komodo VII Power Supply Unit Replacement: step 9, image 2 of 2
    • Lift the power supply unit straight up to remove it from the back panel.
Jose Carrillo
23 Reputation
1 Guide authored
Cal Poly, Team 16-56, Forte Fall 2012 Member of Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 693
