Sceptre X9 Komodo VII Video Motherboard Replacement
  1. Sceptre X9 Komodo VII Video Motherboard Replacement, Stand: step 1, image 1 of 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Video Motherboard Replacement: step 2, image 1 of 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Video Motherboard Replacement, Board Cover: step 3, image 1 of 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Video Motherboard Replacement: step 4, image 1 of 3 Sceptre X9 Komodo VII Video Motherboard Replacement: step 4, image 2 of 3 Sceptre X9 Komodo VII Video Motherboard Replacement: step 4, image 3 of 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Video Motherboard Replacement: step 5, image 1 of 2 Sceptre X9 Komodo VII Video Motherboard Replacement: step 5, image 2 of 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Video Motherboard Replacement, Video Motherboard: step 6, image 1 of 3 Sceptre X9 Komodo VII Video Motherboard Replacement, Video Motherboard: step 6, image 2 of 3 Sceptre X9 Komodo VII Video Motherboard Replacement, Video Motherboard: step 6, image 3 of 3
    • Use caution when removing the connectors as they can easily break when removing.
    • Disconnect the multi-pin connector at the top of the board by firmly grasping the connector and pulling to the side.
    • Disconnect the multi-pin connector that runs between the video motherboard and the power supply motherboard. Firmly grasp the connector and pull straight up.
    • A plastic opening tool can be used to assist in the removal of connectors.
  7. Sceptre X9 Komodo VII Video Motherboard Replacement: step 7, image 1 of 2 Sceptre X9 Komodo VII Video Motherboard Replacement: step 7, image 2 of 2
    • Remove the two 3/16" hex head screws from the VGA connecter. Use a pair of needle nose pliers if a wrench is not available.
  8. Sceptre X9 Komodo VII Video Motherboard Replacement: step 8, image 1 of 1
    • Remove the four 6.4mm #2 Phillips screws from the corners of the motherboard with a #2 Phillips screwdriver.
  9. Sceptre X9 Komodo VII Video Motherboard Replacement: step 9, image 1 of 2 Sceptre X9 Komodo VII Video Motherboard Replacement: step 9, image 2 of 2
    • Lift the motherboard straight up to remove it from the back panel.
David Taylor
10 Reputation
1 Guide authored
Cal Poly, Team 16-56, Forte Fall 2012 Member of Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 664
