Corded Dexter Jigsaw 750 Watts Blade Holder Replacement
Céline Chemineau
Céline Chemineau and one other contributor
Last updated on January 19, 2021
5 minutes
Easy
Community-Contributed Guide
Better Introduction
  1. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement, Unplug: step 1, image 1 of 1
    • Before starting, remember to unplug the device.
  2. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 2, image 1 of 1
    • Remove the vacuum hose adapter at the back of the device.
  3. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 3, image 1 of 2 Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 3, image 2 of 2
    • With the help of a screwdriver, unscrew and open the device.
    • Use the lever to unlock the cover.
    • Using pliers, remove the clip beside the blade holder.
    • Take off the blade holder, then raise the slide located at the end of the holder.
  4. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 6, image 1 of 1
    • First, put the slide onto the new blade bracket.
    • Put the blade bracket back in its place.
    • Make sure to properly put each piece back in its place.
    • Replace the clip in the same place. The curved side of the clip needs to go into the round side of the bracket.
    • Lubricate.
  5. Corded Dexter Jigsaw 750 Watts Blade Holder Replacement: step 9, image 1 of 1
    • Close and screw the device back together.
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,698 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
38 Members
241 Guides authored
2 Comments
Bonjour,
Je suis intéressé pour changer ce support de lame, le mien étant défectueux … les lames ne tiennent plus. Ou est-ce que je peux trouver cette pièce ? Merci Bruno
Bruno - Reply
Le support de lame de ma scie sauteuse dexter nc750js s'est cassée
Ou trouver ce support ?
Aucun revendeur ne semble avoir les pièces de rechange pour cette machine.
Ou, y a t'il une autre marque équivalente?
Bruno Lamothe - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 53
All Time: 3,710
