Screen Prerequisite (No LiDAR Assembly Removal)
Chayton Ritter
Chayton Ritter and one other contributor
Last updated on February 20, 2025
1 - 2 hours
Difficult
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 1 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 2 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 3 of 3
    • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
  2. Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 1 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 2 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 3 of 3
    • Disconnect the two remaining display cables.
  3. Screen Prerequisite (No LiDAR Assembly Removal), Remove the screen: step 3, image 1 of 1
    • Grip the right edge of the screen and lift it away.
    • During reassembly, before installing a display, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
Finish Line
Chayton Ritter
22,518 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
11,420 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 40
