Screen Prerequisite (No LiDAR Assembly Removal)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 1 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 2 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the display cables: step 1, image 3 of 3
    • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
  2. Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 1 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 2 of 3 Screen Prerequisite (No LiDAR Assembly Removal), Disconnect the remaining display cables: step 2, image 3 of 3
    • Disconnect the two remaining display cables.
  3. Screen Prerequisite (No LiDAR Assembly Removal), Remove the screen: step 3, image 1 of 1
    • Grip the right edge of the screen and lift it away.
    • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
Finish Line
Chayton Ritter
25,805 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
16,329 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 60
