Screwless Light Switch Wall Plate Replacement
  1. Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 1 of 3 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 2 of 3 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 3 of 3
    • Caution: Before beginning this guide, turn the light switch off and turn off power to the switch at the circuit breaker.
    • They are usually labeled by the area of the house to which they belong.
  2. Screwless Light Switch Wall Plate Replacement: step 2, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 2, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 2, image 3 of 3
    • Insert a prying tool into the two catches on the top of the light switch.
    • Slowly turn the prying tool or use it as a lever to push the outer plate away from the wall.
  3. Screwless Light Switch Wall Plate Replacement: step 3, image 1 of 1
    • Remove the outer layer of the faceplate.
  4. Screwless Light Switch Wall Plate Replacement: step 4, image 1 of 2 Screwless Light Switch Wall Plate Replacement: step 4, image 2 of 2
    • Remove the inner part of the faceplate by unscrewing the two screws on the top and the bottom.
    • Different faceplates use different screws. Use the screwdriver that works with your screws.
  5. Screwless Light Switch Wall Plate Replacement: step 5, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 5, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 5, image 3 of 3
    • Unbox the new faceplate.
    • Just like Step 2, remove the outer layer of the new faceplate by inserting a prying tool in the catches on its top and bottom, pushing the two layers away from each other.
  6. Screwless Light Switch Wall Plate Replacement: step 6, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 6, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 6, image 3 of 3
    • Hold the inner layer of the faceplate against the wall.
    • Align the holes in the plate with the existing holes on the light switch or power outlet.
    • Tighten the two screws on the top and bottom.
  7. Screwless Light Switch Wall Plate Replacement: step 7, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 7, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 7, image 3 of 3
    • Attach the outer layer of the faceplate by putting it on top of the inner layer and slightly pushing it until you hear a click sound.
You can follow this guide to replace a power outlet faceplate as the procedure is essentially the same.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 146
All Time: 12,765
