Scuf Reflex for PS5: Remove stick drift / jitter
Video Overview
  1. Scuf Reflex for PS5: Remove stick drift / jitter, Scuf Reflex for PS5: Remove stick drift / jitter: step 1, image 1 of 1
    • First, I recommend testing your unit on the free Gamepad Tester to see how it performs.
  2. Scuf Reflex for PS5: Remove stick drift / jitter, Remove Scuf top plate: step 2, image 1 of 2 Scuf Reflex for PS5: Remove stick drift / jitter, Remove Scuf top plate: step 2, image 2 of 2
    • Remove the Scuf top plate by pulling these nibs with your fingers.
  3. Scuf Reflex for PS5: Remove stick drift / jitter, Get your gear: step 3, image 1 of 2 Scuf Reflex for PS5: Remove stick drift / jitter, Get your gear: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Get your gear. You should have
    • A pair of tweezers (ideally angled ones)
    • Q-tips
    • Standard small Philips screwdriver
    • Ideally an angled prodding tool (not displayed).
    • Electronic cleaner / rubbing alcohol
    • Compressed air
  4. Scuf Reflex for PS5: Remove stick drift / jitter, Remove bottom screws: step 4, image 1 of 1
    • Start by unscrewing the bottom screws
  5. Scuf Reflex for PS5: Remove stick drift / jitter, Remove front triggers and screws: step 5, image 1 of 1
    • Remove the L1 / R1 buttons by inserting an angled prodder and pulling straight out. It should come easily.
    • Remove the marked screws as well.
  6. Scuf Reflex for PS5: Remove stick drift / jitter, Remove sticks: step 6, image 1 of 1
    • When you have removed the top plate, Remove the sticks by pulling straight up.
  7. Scuf Reflex for PS5: Remove stick drift / jitter, Remove power cable and battery: step 7, image 1 of 1
    • Prod the device open. No images here, but use a prodding tool and take it slowly. Check out YouTube if you don't know how to progress.
    • The inside of your Scuf controller will look something like this.
    • Unplug and remove the battery (see arrow)
  8. Scuf Reflex for PS5: Remove stick drift / jitter, Flip the board to get access to the sticks: step 8, image 1 of 3 Scuf Reflex for PS5: Remove stick drift / jitter, Flip the board to get access to the sticks: step 8, image 2 of 3 Scuf Reflex for PS5: Remove stick drift / jitter, Flip the board to get access to the sticks: step 8, image 3 of 3
    • Remove the screw from the battery plate
    • Optional, but will make the next step easier: Detach the left cable by pulling on the blue plastic tab.
    • Optional: Remove the right cable with your hand (no plastic tab here, so make sure you don't damage the cord)
    • Then, carefully lift the board out of place. Be aware that there is a light LED (not present in picture) in the green circle that you might have to reposition when reassembling
    • The board is partly held in place by two plastic rods that are mounted in a hole around the blue circles. These are completely loose and can be pulled straight up
  9. Scuf Reflex for PS5: Remove stick drift / jitter, Clean the carbon tracks: step 9, image 1 of 2 Scuf Reflex for PS5: Remove stick drift / jitter, Clean the carbon tracks: step 9, image 2 of 2
    • Use a small, flat and thin screwdriver to pry the joystick potentiometer slots open. Push the slots down about 80°. My screwdriver was was about 1,5mm in width and very thin.
    • Remove the potentiometer for the stick you have a problem with (remember the controller now might be mirrored)
    • Use a q-tip and electronic cleaner to clean the carbon track (everything on the inside of the green plastic) thoroughly.
    • Let it dry and do it again, with a new swab. I recommend doing this multiple times. It was first on my fifth attempt it worked without flaw.
    • Be careful not to let residue from the Q-tips get stuck.
  10. Scuf Reflex for PS5: Remove stick drift / jitter, Clean the wipers: step 10, image 1 of 1
    • Clean the wipers with a q-tip and electronic cleaner. Let it dry. Repeat.
    • Be aware: Do not let fingerprints or residue from the Q-tip get stuck.
    • I have no idea why they are so different in color. They were paired from top to bottom, but only one of my sticks was acting weirdly.
    • I tried removing the corrosion (?) soaking it in rubbing alcohol over night, but it looked the same. I guess these wear out pretty quickly, but they are 3$ for 10x on Aliexpress.
    • PS: After several hits and misses, I used the darker ones on the horizontal axis of the controller. Have no idea if this will help or not.
    • Test it on the Gamepad Tester.
    • After 7-8 tries of varying results, I was amazed that it worked.
    • Disclaimer: I am guessing that this might be a temporary fix. Although I don't quite know the initial state of the carbon tracks, the seem worn and I'm afraid the jitter might return.
    • If so, I would definitely try to replace the carbon tracks and washers first before going into soldering town.
    • Good luck!
Bonka
353 Reputation
2 Guides authored
3 Comments
Thanks for the tip! I’ve tried this over and over but my stick drift is just worse now and maybe I’m putting the wipers in incorrectly but I’m not sure. How many tries until you got it right?
Charlie Peacock - Reply
Hiya, @charliepeacock. I almost gave up myself, thought it was undoable. It also worsened for me, but on the fourth or fifth try, everything suddenly worked. That being said, I was correct in my assumption that it would only be a temporary fix, as it has since gone back to error state. Now, I believe I would do the process, but replace rather than clean the wipers as this is super cheap and provably easier ± freight time for the spare parts.
Bonka - Reply
Hello and thank you for the tip.
It has been worse for me as well.
I can't believe a 300€ controller being so bad quality.
To whoever reads this, don't buy Scuf.
Jerome Majdekomai - Reply
Past 24 Hours: 14
Past 7 Days: 94
Past 30 Days: 371
All Time: 9,284
