Sears Craftsman 315.109020 Motor Replacement
  1. Sears Craftsman 315.109020 Motor Replacement, Motor: step 1, image 1 of 2 Sears Craftsman 315.109020 Motor Replacement, Motor: step 1, image 2 of 2
    • To ensure that you do not get grease and dirt on your table or floor, lay a towel down before you begin working.
    • The grease from the circular saw can stain your towel so a dirty towel or work rag is recommended.
  2. Sears Craftsman 315.109020 Motor Replacement: step 2, image 1 of 3 Sears Craftsman 315.109020 Motor Replacement: step 2, image 2 of 3 Sears Craftsman 315.109020 Motor Replacement: step 2, image 3 of 3
    • With your Phillips screwdriver, unscrew all 7 of the 20 mm screws on the handle of the circular saw.
    • There is one 25 mm screw that goes in the hole circled in red.
    • Unscrew the forked screw head
    • Lift off the top half of the handle.
  3. Sears Craftsman 315.109020 Motor Replacement: step 3, image 1 of 2 Sears Craftsman 315.109020 Motor Replacement: step 3, image 2 of 2
    • Unscrew the two wide-head 20 mm screws holding the remaining half of the handle to the motor.
    • Remove the remaining half of the handle from the motor by lifting it over the screw that is keeping it in place.
  4. Sears Craftsman 315.109020 Motor Replacement: step 4, image 1 of 3 Sears Craftsman 315.109020 Motor Replacement: step 4, image 2 of 3 Sears Craftsman 315.109020 Motor Replacement: step 4, image 3 of 3
    • Using a crescent wrench, unscrew the hex washer head screw that is holding the blade in place.
    • Lift the blade over the internally threaded screw and pull it off of the saw.
    • If the hex washer head screw rotates but does not loosen or if the whole blade rotates as you turn your wrench, giving the wrench a quick jerk should loosen the screw.
  5. Sears Craftsman 315.109020 Motor Replacement: step 5, image 1 of 2 Sears Craftsman 315.109020 Motor Replacement: step 5, image 2 of 2
    • Remove the blade cover by applying upward pressure until it unsnaps from the washer.
    • The blade cover will come off easier if it is facing away from the rest of the saw (see second picture).
  6. Sears Craftsman 315.109020 Motor Replacement: step 6, image 1 of 2 Sears Craftsman 315.109020 Motor Replacement: step 6, image 2 of 2
    • Unscrew the 70 mm screw that is inside the black tube (see first picture).
    • Unscrew the five screws as highlighted in the second picture. The bottom left is a 70 mm screw and the other four are 20 mm screws.
    • Unscrewing the remaining four 20 mm screws are unnecessary unless you wish to repair or replace the cogs in the saw.
  7. Sears Craftsman 315.109020 Motor Replacement: step 7, image 1 of 2 Sears Craftsman 315.109020 Motor Replacement: step 7, image 2 of 2
    • The motor will now be loose and you should be able to twist the motor in a counter-clockwise direction until it is able to be pulled off.
Blake Avant
218 Reputation
2 Guides authored
Cal Poly, Team 17-4, Green Fall 2015 Member of Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 395
