Sega Game Gear Speakers Replacement
Video Overview
  1. Sega Game Gear Speakers Replacement, Battery: step 1, image 1 of 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Speakers Replacement: step 2, image 1 of 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Speakers Replacement, Case: step 3, image 1 of 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Speakers Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Speakers Replacement: step 5, image 1 of 2 Sega Game Gear Speakers Replacement: step 5, image 2 of 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Speakers Replacement: step 6, image 1 of 3 Sega Game Gear Speakers Replacement: step 6, image 2 of 3 Sega Game Gear Speakers Replacement: step 6, image 3 of 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Speakers Replacement, Speakers: step 7, image 1 of 1
    • Unscrew the 8 Phillips screws from the logic board.
  8. Sega Game Gear Speakers Replacement: step 8, image 1 of 1
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Speakers Replacement: step 9, image 1 of 2 Sega Game Gear Speakers Replacement: step 9, image 2 of 2
    • Removing the plastic holding the speaker to the case may permanently detach the speaker.
    • The plastic at these three locations is melted to the plastic. Pry off with caution.
2 other people completed this guide.
Lauren Thurston
461 Reputation
3 Guides authored
Cal Poly, Team 28-33, Regan Spring 2010 Member of Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Members
13 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 47
All Time: 11,977
