Sega Game Gear TV Tuner Disassembly
  1. Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: step 1, image 1 of 2 Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: step 1, image 2 of 2
    • Remove PH1 screw and lift up on the antenna to remove it
    • This can be done with a PH0 screwdriver but I prefer not to risk stripping the screw
    • Remove 4 PH0 screws
    • Remove 2 3.8mm gamebit screws
    • Lift rear tuner shell away from unit
  2. Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 1 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 2 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 3 of 3
    • Before we can remove the motherboard the tint wheel needs to be removed
    • A peek on the inside reveals 2 small retaining clips. Simply apply some pressure on the clips with a needle nose tweezer
    • When reinstalling the tint wheel simply align the retaining clips with the holes and press back into place
    • Remove the motherboard from the unit
  3. Sega Game Gear TV Tuner Disassembly, Remove PCBs: step 3, image 1 of 2 Sega Game Gear TV Tuner Disassembly, Remove PCBs: step 3, image 2 of 2
    • When removing the front shell be careful not to lose the frequency switch button located on top of the device
    • If it makes your repair easier you can separate the two PCBs by gently pulling the ribbon out of its connector. This is a friction fit cable
  4. Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 1 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 2 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 3 of 3
    • Flip the PCBs over with the back side facing you.
    • Remove 1 PH0 screw
    • Flip the board over again and gently pull the tuning dial assembly out of the pin header socket
2 other people completed this guide.
Navy Vet 2015
7,382 Reputation
15 Guides authored
3 Comments
does anybody know what the ribbon cables pinout is? I would love to know, so I can hook up some video-in to the tv tuner board, since my good guess is, that the upper part is just transporting or converting the signal it gets from its receiver to a mere video-in signal with LandR audio, since you can also hook up video-in to the tv tuner on the jack. and my other wild guess is, that the board the actual receiver is hooked up to splits up the signal into 8-bit chunks the game gear itself can understand. Please feel free to correct me and give more info, i NEED the pinout, since i got no tools at home to check what the ribbon cable actually is cooking.
patoschkapeter - Reply
A small washer fell out of mine when I was taking it apart. Any idea where it goes?
Kyle Mitchell - Reply
If it's very thin and small circumference it goes between the antenna and swivel. There may be 2 of them.
Navy Vet 2015 -
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 32
All Time: 3,223
