Sega Genesis Outer Case Replacement
  1. Sega Genesis Outer Case Replacement, Outer Case: step 1, image 1 of 1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Outer Case Replacement: step 2, image 1 of 1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Outer Case Replacement: step 3, image 1 of 1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Outer Case Replacement: step 4, image 1 of 1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Outer Case Replacement: step 5, image 1 of 1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Outer Case Replacement: step 6, image 1 of 1
    • Separate the main board from the outer case.
17 other people completed this guide.
Erik Bjornstrom
852 Reputation
3 Guides authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 72
All Time: 22,261
