Sega Genesis Reset Button Repair
  1. Sega Genesis Reset Button Repair, Outer Case: step 1, image 1 of 1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Reset Button Repair: step 2, image 1 of 1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Reset Button Repair: step 3, image 1 of 1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Reset Button Repair: step 4, image 1 of 1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Reset Button Repair: step 5, image 1 of 1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Reset Button Repair: step 6, image 1 of 1
    • Separate the main board from the outer case.
  7. Sega Genesis Reset Button Repair, Sega Genesis Reset Button Repair: step 7, image 1 of 1
    • Using Philips screwdriver, remove 11 screws securing silver casing.
  8. Sega Genesis Reset Button Repair: step 8, image 1 of 1
    • Remove silver case.
  9. Sega Genesis Reset Button Repair: step 9, image 1 of 1
    • Locate reset button on motherboard
  10. Sega Genesis Reset Button Repair: step 10, image 1 of 1
    • Place three pieces of 1cm x 1cm masking tape over reset button.
To reassemble your device, follow these instructions in reverse order. And the most important, be happy!
calvin
249 Reputation
1 Guide authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 59
All Time: 18,161
