Sega Saturn Battery Replacement
  1. Sega Saturn Battery Replacement, Battery: step 1, image 1 of 2 Sega Saturn Battery Replacement, Battery: step 1, image 2 of 2
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Battery Replacement: step 2, image 1 of 3 Sega Saturn Battery Replacement: step 2, image 2 of 3 Sega Saturn Battery Replacement: step 2, image 3 of 3
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Battery Replacement: step 3, image 1 of 3 Sega Saturn Battery Replacement: step 3, image 2 of 3 Sega Saturn Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use the ESD safe tweezers to pull the battery out of its slot.
2 other people completed this guide.
Jan Ulloa
630 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2019 Member of USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
3 Members
18 Guides authored
One Comment
Japanese Saturn? Here's how to set English after battery replacement...
Turn on the console without a disc inside.
If you get the date/time set screen, press the right direction until you have highlighted the bottom-right symbol then press A.
In the main system menu, select the icon that looks like a box with up-down arrow inside.
Next screen, choose bottom-right option.
In the next menu, select the item in the center (it’s the 2nd option)
Pick English (is not kanji) then select Exit.
Andy Craig - Reply
Past 24 Hours: 10
Past 7 Days: 63
Past 30 Days: 301
All Time: 11,626
