Segway Ninebot Max Front Tire Repacement
  1. Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 1 of 3 Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 2 of 3 Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 3 of 3
    • Before beginning the guide make sure the scooter is off and placed on a stand or table for easier access to work on.
    • Remove the cap and reflection tag using a slotted screwdriver.
  2. Segway Ninebot Max Front Tire Repacement: step 2, image 1 of 3 Segway Ninebot Max Front Tire Repacement: step 2, image 2 of 3 Segway Ninebot Max Front Tire Repacement: step 2, image 3 of 3
    • Use 3 mm Allen key to loosen three hexagon screws from each side of the wheel.
  3. Segway Ninebot Max Front Tire Repacement: step 3, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 3, image 2 of 2
    • Snap the covers away from the scooter from both sides.
    • Remove the covers slowly and steadily to avoid breaking it.
  4. Segway Ninebot Max Front Tire Repacement: step 4, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 4, image 2 of 2
    • To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
  5. Segway Ninebot Max Front Tire Repacement: step 5, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 5, image 2 of 2
    • Use a 15 mm socket wrench to remove 15mm bolt from the tire of the scooter on both sides of the front wheel.
  6. Segway Ninebot Max Front Tire Repacement: step 6, image 1 of 1
    • Pull down the tire and remove it from the frame.
6 other people completed this guide.
Shafran Jamal
285 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 222
All Time: 13,738
