Sensor Array Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Sensor Array Removal, Reposition the head strap: step 1, image 1 of 2 Sensor Array Removal, Reposition the head strap: step 1, image 2 of 2
    • Rotate the head strap forward as far as it will go.
  2. Sensor Array Removal, Unplug the All-In-One Cable: step 2, image 1 of 2 Sensor Array Removal, Unplug the All-In-One Cable: step 2, image 2 of 2
    • Unplug the All-In-One Cable from your headset.
  3. Sensor Array Removal, Remove the All-In-One Cable: step 3, image 1 of 3 Sensor Array Removal, Remove the All-In-One Cable: step 3, image 2 of 3 Sensor Array Removal, Remove the All-In-One Cable: step 3, image 3 of 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Sensor Array Removal, Remove the top strap: step 4, image 1 of 2 Sensor Array Removal, Remove the top strap: step 4, image 2 of 2
    • Separate the top strap from itself where the Velcro secures it.
  5. Sensor Array Removal: step 5, image 1 of 3 Sensor Array Removal: step 5, image 2 of 3 Sensor Array Removal: step 5, image 3 of 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Sensor Array Removal: step 6, image 1 of 3 Sensor Array Removal: step 6, image 2 of 3 Sensor Array Removal: step 6, image 3 of 3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Sensor Array Removal, Remove the front side foam pads: step 7, image 1 of 3 Sensor Array Removal, Remove the front side foam pads: step 7, image 2 of 3 Sensor Array Removal, Remove the front side foam pads: step 7, image 3 of 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Sensor Array Removal, Remove the two rubber spacers: step 8, image 1 of 3 Sensor Array Removal, Remove the two rubber spacers: step 8, image 2 of 3 Sensor Array Removal, Remove the two rubber spacers: step 8, image 3 of 3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Sensor Array Removal, Disconnect the speaker wires: step 9, image 1 of 3 Sensor Array Removal, Disconnect the speaker wires: step 9, image 2 of 3 Sensor Array Removal, Disconnect the speaker wires: step 9, image 3 of 3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Sensor Array Removal, Remove the head strap: step 10, image 1 of 2 Sensor Array Removal, Remove the head strap: step 10, image 2 of 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Sensor Array Removal: step 11, image 1 of 1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Sensor Array Removal: step 12, image 1 of 3 Sensor Array Removal: step 12, image 2 of 3 Sensor Array Removal: step 12, image 3 of 3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Sensor Array Removal, Remove the outer shell: step 13, image 1 of 3 Sensor Array Removal, Remove the outer shell: step 13, image 2 of 3 Sensor Array Removal, Remove the outer shell: step 13, image 3 of 3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Sensor Array Removal: step 14, image 1 of 2 Sensor Array Removal: step 14, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Sensor Array Removal: step 15, image 1 of 3 Sensor Array Removal: step 15, image 2 of 3 Sensor Array Removal: step 15, image 3 of 3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Sensor Array Removal: step 16, image 1 of 3 Sensor Array Removal: step 16, image 2 of 3 Sensor Array Removal: step 16, image 3 of 3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Sensor Array Removal: step 17, image 1 of 3 Sensor Array Removal: step 17, image 2 of 3 Sensor Array Removal: step 17, image 3 of 3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. Sensor Array Removal, Remove the face rest cushion: step 18, image 1 of 3 Sensor Array Removal, Remove the face rest cushion: step 18, image 2 of 3 Sensor Array Removal, Remove the face rest cushion: step 18, image 3 of 3
    • Use your fingers to gently peel the face rest cushion off of the headset.
  19. Sensor Array Removal, Remove the facerest: step 19, image 1 of 2 Sensor Array Removal, Remove the facerest: step 19, image 2 of 2
    • Partially separate the facerest and the sensor array to access the daughterboard.
  20. Sensor Array Removal: step 20, image 1 of 2 Sensor Array Removal: step 20, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  21. Sensor Array Removal: step 21, image 1 of 3 Sensor Array Removal: step 21, image 2 of 3 Sensor Array Removal: step 21, image 3 of 3
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  22. Sensor Array Removal: step 22, image 1 of 2 Sensor Array Removal: step 22, image 2 of 2
    • Slide the facerest out of the front assembly.
  23. Sensor Array Removal, Remove the sensor array: step 23, image 1 of 2 Sensor Array Removal, Remove the sensor array: step 23, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
  24. Sensor Array Removal: step 24, image 1 of 3 Sensor Array Removal: step 24, image 2 of 3 Sensor Array Removal: step 24, image 3 of 3
    • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
    • Use a pair of tweezers to slide the ribbon cable out of its socket.
  25. Sensor Array Removal: step 25, image 1 of 2 Sensor Array Removal: step 25, image 2 of 2
    • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
  26. Sensor Array Removal: step 26, image 1 of 3 Sensor Array Removal: step 26, image 2 of 3 Sensor Array Removal: step 26, image 3 of 3
    • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
    • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
  27. Sensor Array Removal: step 27, image 1 of 2 Sensor Array Removal: step 27, image 2 of 2
    • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
    • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
  28. Sensor Array Removal: step 28, image 1 of 2 Sensor Array Removal: step 28, image 2 of 2
    • Lift the sensor array straight up off of the lens and OLED assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
93,187 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 42
