Sensor Array Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Sensor Array Removal, Reposition the head strap: step 1, image 1 of 2 Sensor Array Removal, Reposition the head strap: step 1, image 2 of 2
    • Rotate the head strap forward as far as it will go.
  2. Sensor Array Removal, Unplug the All-In-One Cable: step 2, image 1 of 2 Sensor Array Removal, Unplug the All-In-One Cable: step 2, image 2 of 2
    • Unplug the All-In-One Cable from your headset.
  3. Sensor Array Removal, Remove the All-In-One Cable: step 3, image 1 of 3 Sensor Array Removal, Remove the All-In-One Cable: step 3, image 2 of 3 Sensor Array Removal, Remove the All-In-One Cable: step 3, image 3 of 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Sensor Array Removal, Remove the top strap: step 4, image 1 of 2 Sensor Array Removal, Remove the top strap: step 4, image 2 of 2
    • Separate the top strap from itself where the Velcro secures it.
  5. Sensor Array Removal: step 5, image 1 of 3 Sensor Array Removal: step 5, image 2 of 3 Sensor Array Removal: step 5, image 3 of 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Sensor Array Removal: step 6, image 1 of 3 Sensor Array Removal: step 6, image 2 of 3 Sensor Array Removal: step 6, image 3 of 3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Sensor Array Removal, Remove the front side foam pads: step 7, image 1 of 3 Sensor Array Removal, Remove the front side foam pads: step 7, image 2 of 3 Sensor Array Removal, Remove the front side foam pads: step 7, image 3 of 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Sensor Array Removal, Remove the two rubber spacers: step 8, image 1 of 3 Sensor Array Removal, Remove the two rubber spacers: step 8, image 2 of 3 Sensor Array Removal, Remove the two rubber spacers: step 8, image 3 of 3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Sensor Array Removal, Disconnect the speaker wires: step 9, image 1 of 3 Sensor Array Removal, Disconnect the speaker wires: step 9, image 2 of 3 Sensor Array Removal, Disconnect the speaker wires: step 9, image 3 of 3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Sensor Array Removal, Remove the head strap: step 10, image 1 of 2 Sensor Array Removal, Remove the head strap: step 10, image 2 of 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Sensor Array Removal: step 11, image 1 of 1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Sensor Array Removal: step 12, image 1 of 3 Sensor Array Removal: step 12, image 2 of 3 Sensor Array Removal: step 12, image 3 of 3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Sensor Array Removal, Remove the outer shell: step 13, image 1 of 3 Sensor Array Removal, Remove the outer shell: step 13, image 2 of 3 Sensor Array Removal, Remove the outer shell: step 13, image 3 of 3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Sensor Array Removal: step 14, image 1 of 2 Sensor Array Removal: step 14, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Sensor Array Removal: step 15, image 1 of 3 Sensor Array Removal: step 15, image 2 of 3 Sensor Array Removal: step 15, image 3 of 3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Sensor Array Removal: step 16, image 1 of 3 Sensor Array Removal: step 16, image 2 of 3 Sensor Array Removal: step 16, image 3 of 3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Sensor Array Removal: step 17, image 1 of 3 Sensor Array Removal: step 17, image 2 of 3 Sensor Array Removal: step 17, image 3 of 3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. Sensor Array Removal, Disconnect the microphone: step 18, image 1 of 2 Sensor Array Removal, Disconnect the microphone: step 18, image 2 of 2
    • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
  19. Sensor Array Removal: step 19, image 1 of 2 Sensor Array Removal: step 19, image 2 of 2
    • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
  20. Sensor Array Removal, Disconnect the sensor array: step 20, image 1 of 2 Sensor Array Removal, Disconnect the sensor array: step 20, image 2 of 2
    • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
  21. Sensor Array Removal: step 21, image 1 of 2 Sensor Array Removal: step 21, image 2 of 2
    • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
  22. Sensor Array Removal: step 22, image 1 of 1
    • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
  23. Sensor Array Removal, Remove the sensor array screws: step 23, image 1 of 2 Sensor Array Removal, Remove the sensor array screws: step 23, image 2 of 2
    • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
  24. Sensor Array Removal: step 24, image 1 of 3 Sensor Array Removal: step 24, image 2 of 3 Sensor Array Removal: step 24, image 3 of 3
    • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
  25. Sensor Array Removal, Remove the sensor array: step 25, image 1 of 2 Sensor Array Removal, Remove the sensor array: step 25, image 2 of 2
    • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
    • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
Alex Diaz-Kokaisl
215,350 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 85
