Sew a Straight Stitch
  1. Sew a Straight Stitch, Sew a Straight Stitch: step 1, image 1 of 2 Sew a Straight Stitch, Sew a Straight Stitch: step 1, image 2 of 2
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
  2. Sew a Straight Stitch: step 2, image 1 of 2 Sew a Straight Stitch: step 2, image 2 of 2
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
  3. Sew a Straight Stitch: step 3, image 1 of 2 Sew a Straight Stitch: step 3, image 2 of 2
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
  4. Sew a Straight Stitch: step 4, image 1 of 2 Sew a Straight Stitch: step 4, image 2 of 2
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
  5. Sew a Straight Stitch: step 5, image 1 of 3 Sew a Straight Stitch: step 5, image 2 of 3 Sew a Straight Stitch: step 5, image 3 of 3
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
  6. Sew a Straight Stitch: step 6, image 1 of 1
    • Cut any remaining thread and admire your work.
Finish Line
4 other people completed this guide.
Brittany McCrigler
90,612 Reputation
142 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 100
All Time: 4,539
