Sew-on Patch
  1. Sew-on Patch, Sew-on Patch: step 1, image 1 of 2 Sew-on Patch, Sew-on Patch: step 1, image 2 of 2
    • Examine the damage. Clip any loose threads and remove any debris from the tear.
    • Grab a trendy patch.
  2. Sew-on Patch: step 2, image 1 of 2 Sew-on Patch: step 2, image 2 of 2
    • Position the patch over the hole.
    • Any patch you use should overlap the damage by at least 1/8".
  3. Sew-on Patch: step 3, image 1 of 3 Sew-on Patch: step 3, image 2 of 3 Sew-on Patch: step 3, image 3 of 3
    • Pin the patch to the jeans.
    • Be sure to only pin the patch to one layer of denim, or you will sew the pants shut.
  4. Sew-on Patch: step 4, image 1 of 3 Sew-on Patch: step 4, image 2 of 3 Sew-on Patch: step 4, image 3 of 3
    • Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
    • Be sure you only have one layer of the jeans between the needle and the sewing machine arm, or you will sew the pants shut.
  5. Sew-on Patch: step 5, image 1 of 2 Sew-on Patch: step 5, image 2 of 2
    • Lower the pressor foot.
    • Sew along the edge of the patch.
    • Remove the pins before you get to them.
    • Sewing over a pin can bend or break the needle.
  6. Sew-on Patch: step 6, image 1 of 2 Sew-on Patch: step 6, image 2 of 2
    • Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
  7. Sew-on Patch: step 7, image 1 of 3 Sew-on Patch: step 7, image 2 of 3 Sew-on Patch: step 7, image 3 of 3
    • When you come all the way around, overlap the first two or three stitches.
    • Lift the needle and pressor foot.
    • Slide the jeans out of the sewing machine.
    • Clip any threads, and admire your work.
Finish Line
4 other people completed this guide.
Brittany McCrigler
90,475 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,758 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 83
All Time: 9,443
