Shank Button Replacement
  1. Shank Button Replacement, Shank Button: step 1, image 1 of 3 Shank Button Replacement, Shank Button: step 1, image 2 of 3 Shank Button Replacement, Shank Button: step 1, image 3 of 3
    • Remove your loose button (if necessary).
    • If the button is already missing, remove any loose threads from your garment.
    • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
  2. Shank Button Replacement: step 2, image 1 of 3 Shank Button Replacement: step 2, image 2 of 3 Shank Button Replacement: step 2, image 3 of 3
    • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
    • Thread your needle.
    • Pull the thread until two equal parts are on either side of the needle.
    • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
  3. Shank Button Replacement: step 3, image 1 of 3 Shank Button Replacement: step 3, image 2 of 3 Shank Button Replacement: step 3, image 3 of 3
    • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
    • Pull the thread until the knot rests on the fabric.
    • Insert your needle into the shank on the back of your button.
    • Pull the thread until the button rests on the fabric.
    • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
  4. Shank Button Replacement: step 4, image 1 of 3 Shank Button Replacement: step 4, image 2 of 3 Shank Button Replacement: step 4, image 3 of 3
    • To tie off your thread, insert the needle back into the fabric near your previous stitches.
    • Pull thread until there is a small loop (do not pull flush with fabric).
    • Insert the needle into the thread loop and pull through.
    • Pull the thread until the loop closes and a knot is formed.
  5. Shank Button Replacement: step 5, image 1 of 3 Shank Button Replacement: step 5, image 2 of 3 Shank Button Replacement: step 5, image 3 of 3
    • Trim any excess thread from the button area.
    • Enjoy your newly repaired item!
Finish Line
Rebekah Kilpatrick
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 48
All Time: 631
