Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement
  1. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement, Hose: step 1, image 1 of 2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement, Hose: step 1, image 2 of 2
    • Press the button titled "Hose Release" to detach the hose from the dust cup.
  2. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 2, image 1 of 2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 2, image 2 of 2
    • Check the hose and opening on the back of the connector for blockages and remove any that you encounter.
  3. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 3, image 1 of 2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 3, image 2 of 2
    • Disconnect the hose attachment in the middle of the wand.
  4. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 4, image 1 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 4, image 2 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 4, image 3 of 3
    • Detach the wand from the floor nozzle by pressing the button titled "Wand Release."
    • Check the opening of the bottom of the wand for blockages and remove any that you encounter.
  5. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 5, image 1 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 5, image 2 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 5, image 3 of 3
    • Detach the handle by pressing the button titled "Handle Release."
    • Check the opening at the top of the wand and the opening of the handle for any blockages and remove any that you encounter.
    • Keep the handle removed from the wand.
  6. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 6, image 1 of 2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 6, image 2 of 2
    • Detach the dust cup from the floor nozzle.
  7. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 7, image 1 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 7, image 2 of 3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 7, image 3 of 3
    • Tilt the floor nozzle downwards.
    • Check the opening of the floor nozzle for blockages and remove any that you encounter.
  8. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 8, image 1 of 2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: step 8, image 2 of 2
    • Check the end of the hose that is not directly attached to the handle for any blockage and remove any that you encounter.
To reassemble your device, follow these instructions in reverse order. You will know when the pieces have reconnected if you hear a "click" sound.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 207
