Shark DuoClean Powered Lift-Away Speed Filter Replacement
  1. Shark DuoClean Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 1 of 3 Shark DuoClean Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 2 of 3 Shark DuoClean Powered Lift-Away Speed Filter Replacement, Filter: step 1, image 3 of 3
    • Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
  2. Shark DuoClean Powered Lift-Away Speed Filter Replacement: step 2, image 1 of 1
    • Pull up on the filter tab to remove the large foam filter.
  3. Shark DuoClean Powered Lift-Away Speed Filter Replacement: step 3, image 1 of 1
    • Pull up on the small tab to remove the filter pad.
Catie Halvorsen
703 Reputation
5 Guides authored
Cal Poly, Team S17-G4, White Fall 2018 Member of Cal Poly, Team S17-G4, White Fall 2018
CPSU-WHITE-F18S17G4
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 124
All Time: 9,320
