Shark Flex DuoClean Motherboard Replacement
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: step 1, image 1 of 2 Shark Flex DuoClean Motherboard Replacement, Garage Door: step 1, image 2 of 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: step 2, image 1 of 2 Shark Flex DuoClean Motherboard Replacement, Side Component: step 2, image 2 of 2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: step 3, image 1 of 2 Shark Flex DuoClean Motherboard Replacement: step 3, image 2 of 2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: step 4, image 1 of 1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: step 5, image 1 of 1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: step 6, image 1 of 1
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: step 7, image 1 of 2 Shark Flex DuoClean Motherboard Replacement: step 7, image 2 of 2
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: step 9, image 1 of 1
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: step 10, image 1 of 1
    • Desolder the motherboard wires using wire cutters.
Samantha Mickelson
496 Reputation
4 Guides authored
Cal Poly, Team S17-G5, White Fall 2018 Member of Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,439
