Shark Flex DuoClean Power Cord Replacement
  1. Shark Flex DuoClean Power Cord Replacement, Dust Cup: step 1, image 1 of 2 Shark Flex DuoClean Power Cord Replacement, Dust Cup: step 1, image 2 of 2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Power Cord Replacement, Power Cord: step 2, image 1 of 2 Shark Flex DuoClean Power Cord Replacement, Power Cord: step 2, image 2 of 2
    • Remove the pre-motor filter with your hands.
  3. Shark Flex DuoClean Power Cord Replacement: step 3, image 1 of 1
    • Remove the post-motor filter.
  4. Shark Flex DuoClean Power Cord Replacement: step 4, image 1 of 1
    • Remove the two 15 mm screws by twisting counterclockwise with the T10 Torx screwdriver.
  5. Shark Flex DuoClean Power Cord Replacement: step 5, image 1 of 2 Shark Flex DuoClean Power Cord Replacement: step 5, image 2 of 2
    • Remove the two 12 mm screws by twisting counterclockwise with the T15 Torx screwdriver.
    • To fully remove the power cord, cut the wires using a wire cutter.
    • For reassembly, use the soldering guide in the Introduction.
2 other people completed this guide.
caoimhe
979 Reputation
4 Guides authored
Cal Poly, Team S17-G5, White Fall 2018 Member of Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Members
14 Guides authored
One Comment
I found with further dissasembly, uncrimping and recrimping the wiring loom saved having to add more connections.
qwazew - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 1,429
