Shark ION Robot 750 Outer Shell Replacement
  1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Outer Shell Replacement: step 2, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 2, image 2 of 2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Outer Shell Replacement: step 3, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 3, image 2 of 2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Outer Shell Replacement: step 4, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 4, image 2 of 2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Outer Shell Replacement: step 5, image 1 of 3 Shark ION Robot 750 Outer Shell Replacement: step 5, image 2 of 3 Shark ION Robot 750 Outer Shell Replacement: step 5, image 3 of 3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Outer Shell Replacement: step 6, image 1 of 1
    • Lift the outer shell to expose the Shark’s interior.
Youness Elfath
183 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 109
