Shark ION Robot R75 Caster Wheel Replacement
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: step 1, image 1 of 1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: step 2, image 1 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 2, image 2 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: step 3, image 1 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 3, image 2 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 3, image 3 of 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
One Comment
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 88
All Time: 5,262
