Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: step 1, image 1 of 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
    I would add markup and action shots here. Which cover? Make sure to specifically identify device components.
    Alex Watkins - Reply
  2. Shark ION Robot R75 Main Brush Replacement: step 2, image 1 of 1
    • Pull the main brush slightly to the right to remove it from the compartment.
    When will you know that you’ve pulled far enough to the right? When you say remove, do you need to lift the brush up? Do you have more action shots demonstrating this procedure?
    Right. Mine does not budge, and I don’t want to break the mounts.
    EiEiOh - Reply
  3. Shark ION Robot R75 Main Brush Replacement: step 3, image 1 of 2 Shark ION Robot R75 Main Brush Replacement: step 3, image 2 of 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
    Be sure to check special bullets. Indicate how to remove the end cap.
One Comment
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 40
All Time: 2,977
