Shark ION Robot R75 Side Brush Motor Replacement
  1. Shark ION Robot R75 Side Brush Motor Replacement, Battery: step 1, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Battery: step 1, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Battery: step 1, image 3 of 3
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
  2. Shark ION Robot R75 Side Brush Motor Replacement: step 2, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 2, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 2, image 3 of 3
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
  3. Shark ION Robot R75 Side Brush Motor Replacement: step 3, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
  4. Shark ION Robot R75 Side Brush Motor Replacement, Main Brush: step 4, image 1 of 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  5. Shark ION Robot R75 Side Brush Motor Replacement: step 5, image 1 of 1
    • Pull the main brush slightly to the right to remove it from the compartment.
  6. Shark ION Robot R75 Side Brush Motor Replacement: step 6, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 6, image 2 of 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
  7. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: step 7, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: step 7, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: step 7, image 3 of 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
  8. Shark ION Robot R75 Side Brush Motor Replacement, Drive Wheel Assembly: step 8, image 1 of 1
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
  9. Shark ION Robot R75 Side Brush Motor Replacement: step 9, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 9, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 9, image 3 of 3
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
  10. Shark ION Robot R75 Side Brush Motor Replacement: step 10, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 10, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 10, image 3 of 3
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
  11. Shark ION Robot R75 Side Brush Motor Replacement, Shark ION Robot R75 Caster Wheel: step 11, image 1 of 1
    • Orient the device with the bottom facing up.
  12. Shark ION Robot R75 Side Brush Motor Replacement: step 12, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 12, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 12, image 3 of 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  13. Shark ION Robot R75 Side Brush Motor Replacement: step 13, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 13, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 13, image 3 of 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
  14. Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: step 14, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: step 14, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: step 14, image 3 of 3
    • Push down on the black tab and remove the dust bin
  15. Shark ION Robot R75 Side Brush Motor Replacement: step 15, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 15, image 2 of 2
    • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
  16. Shark ION Robot R75 Side Brush Motor Replacement: step 16, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 16, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 16, image 3 of 3
    • Make sure the robot is facing rearward
    • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
    • Pull the bottom part of the bump guard away from the body of the device.
  17. Shark ION Robot R75 Side Brush Motor Replacement: step 17, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 17, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 17, image 3 of 3
    • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
    • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
    • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
  18. Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: step 18, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: step 18, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
    • Slide the sensor out from the base of the robot
  19. Shark ION Robot R75 Side Brush Motor Replacement: step 19, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 19, image 2 of 2
    • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
  20. Shark ION Robot R75 Side Brush Motor Replacement: step 20, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 20, image 2 of 2
    • Disconnect the white connector from the sensor.
  21. Shark ION Robot R75 Side Brush Motor Replacement: step 21, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement: step 21, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the screw on the sensor.
    • Remove the sensor from its mount.
  22. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: step 22, image 1 of 2 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: step 22, image 2 of 2
    • Make sure that both the left and right side sensors have been removed from their compartments.
    • Using a Phillips #0 screwdriver, remove the two screws on either side of the motherboard.
  23. Shark ION Robot R75 Side Brush Motor Replacement: step 23, image 1 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 23, image 2 of 3 Shark ION Robot R75 Side Brush Motor Replacement: step 23, image 3 of 3
    • Place your fingers in the groove right above the bump sensor.
    • Carefully lift the motherboard and plastic assembly up to expose the motors and charging contacts.
  24. Shark ION Robot R75 Side Brush Motor Replacement: step 24, image 1 of 1
    • Lift the malfunctioning motor from its slot in the device.
    • Desolder the two connections on the faulty motor.
    • If you're unfamiliar with soldering techniques and best practices, check out our How to Solder and Desolder Connections guide!
4 other people completed this guide.
5 Comments
What is the motor part that is being replaced?
Cheryl Bobo - Reply
I have a different question.
My ion 75 will clean for three minutes, and then it returns to dock. I have cleaned everything underneath but have not unscrewed anything. Popped the wheels and brushes and used Qtip on the side sensors. I charged directly from the wall (bypassing the charger) and had the same result….. three minutes cleaning and returns to dock.
Am I being premature to suspect a battery replacement is needed? This detailed article of yours has me wondering.
flea
Gail Burgess - Reply
My ion RV870 series just stopped working flashes blue max. I have checked all components and cleaned. It has a good charge. I see no dysfunction what so ever. How do I get it working again?? I'm out of ideas because everything seems to be functional and clean.
Gina Madore - Reply
These were awesome instructions for me. Mine had hair wrapped around the brush motor spindle. Before fix it would come off the dock and stop after like 1 foot. After tear down and full clean, it went over an hour. Thank you!
Naz Lazar - Reply
I have the Shark IQ, this was very similar and absolutely awesome. Thanks so much
Lance Plummer - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 84
All Time: 8,157
