Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment Replacement
  1. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: step 1, image 1 of 2 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: step 1, image 2 of 2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: step 2, image 1 of 2 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: step 2, image 2 of 2
    • Disconnect the hand-held steamer unit from the accessory extension hose.
    • Grip the hand-held steamer and push down on the two release buttons.
    • Gently pull the accessory extension hose out in a horizontal motion until it disconnects.
    • When reassembling, be sure to insert the base of the hand-held unit first.
    • If you have any problems with the hand-held steamer locking into place, please consult our Troubleshooting Page.
    • While the accessory extension hose is not pictured here, the procedure is the same.
Rachel Howe
261 Reputation
2 Guides authored
UW Tacoma, Team S1-G3, Rose Fall 2018 Member of UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
4 Members
10 Guides authored
2 Comments
What if it won't allow to power on once reassembled? The light flashes but won't click on.
Aubrey Diaz - Reply
really?? take it on and off with more words.... how about something helpful like where this stupid little rubber band goes so that the trigger is actuated when the unit is placed in the floor mopper. pat yourself on the back you rewrote the basic user instructions and called it a repair. thanks for the complete waste of my time
Jessica Mcallister - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 2,607
