Shark NV352 Filter Replacement
  1. Shark NV352 Filter Replacement, Filter: step 1, image 1 of 1
    • Ensure that you are removing the filters from the vacuum in an area that you don't mind getting dirty because the filters will be very dusty.
    • Lift the latches on both sides of the vacuum to release the dust canister.
  2. Shark NV352 Filter Replacement: step 2, image 1 of 2 Shark NV352 Filter Replacement: step 2, image 2 of 2
    • Tilt the dust canister forward to release it from its position.
    • Carefully lift away the dust canister and set it aside.
  3. Shark NV352 Filter Replacement: step 3, image 1 of 3 Shark NV352 Filter Replacement: step 3, image 2 of 3 Shark NV352 Filter Replacement: step 3, image 3 of 3
    • Remove the upper filter by lifting upwards on it.
    • Now that the lower filter is exposed, remove it by pulling it upwards.
5 other people completed this guide.
Vincent Leuzze
309 Reputation
1 Guide authored
Cal Poly, Team S18-G5, Forte Fall 2017 Member of Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,234
