Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: step 1, image 1 of 1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 2, image 1 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 2, image 2 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 2, image 3 of 3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 3, image 1 of 2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 3, image 2 of 2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 4, image 1 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 4, image 2 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 4, image 3 of 3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 5, image 1 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 5, image 2 of 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: step 5, image 3 of 3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
2 other people completed this guide.
Pramika Kumar
258 Reputation
1 Guide authored
Cal Poly, Team S15-G2, Livingston Fall 2017 Member of Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 19
Past 30 Days: 54
All Time: 5,055
