Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: step 1, image 1 of 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: step 1, image 2 of 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: step 1, image 3 of 3
    • Press the latch below the HEPA filter on the bottom of the front body of the vacuum and pull outwards with your hands.
    • Pull the grey and blue plastic cover down and away with your hands.
  2. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: step 2, image 1 of 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: step 2, image 2 of 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: step 2, image 3 of 3
    • Pull the HEPA filter out by the grey plastic tab in the middle of the grate with your hands.
    • Wiggle it around as you are pulling if the HEPA filter is not coming out easily.
Elena Postupalskaya
1,177 Reputation
6 Guides authored
Cal Poly, Team S15-G2, Livingston Fall 2017 Member of Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Members
14 Guides authored
One Comment
I bought two different HEPA filters for the front, and they just blow off. What is the part with the tab that you push down to get the filter out? Is that an extra part cuz I don't even have that.
Kelly Kusemamuriwo - Reply
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 105
All Time: 6,522
