Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: step 1, image 1 of 2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: step 1, image 2 of 2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: step 2, image 1 of 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: step 2, image 2 of 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: step 2, image 3 of 3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: step 3, image 1 of 1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
2 other people completed this guide.
Attached Documents
Nadir Abdusemed
124 Reputation
1 Guide authored
One Comment
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - Reply
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 158
All Time: 4,326
